Compression question?
Old Aug 25, 2006 | 10:17 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Old Aug 25, 2006 | 11:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
here's a calculator
United Engine and Machine Co.
I think your stock deck height is .025"
I don't know what volume the stock pistons are. Usually aftermarket flat tops with 4 eyebrows are 5cc, but I think the stockers would have to be larger.
3.48" stroke
and whatever gasket you've used.
I was trying to do it for you, but I couldn't get the right CR to begin with, since I couldn't get the right piston volume in.... Anyway, you're looking at
~.7 of a CR point. Pretty big jump
Old Aug 25, 2006 | 11:55 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
