code 42
Old Aug 26, 2006 | 03:11 PM
gasman305h.o.'s Avatar
Car: 1984 Pontiac Trans Am
Axle/Gears: 9 bolt posi 3.27
code 42
OK so my car keeps giving me a code 42 which is Ignition system problem , electric spark timing(EST) Circuit Fualt. its a 84 t/a with a rebuilt 305. Its got a new distributor and knock sensor. I'm leaning towards the computer, but I dont want to buy somethign that isn't going to fix the problem. Also it gets **** gas milage now since that code has come up and my plugs apear to be fouled from having too much gas. So does anyone have any suggestions? It would be much appreciated
Old Aug 26, 2006 | 10:14 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Is the 4 wire connector connected at the distributor? That's the one to disconnect for initial timing. Otherwise it may be a wiring problem or module problem. I doubt it's the computer. Bad wiring connections are the hardest to find.
Old Aug 27, 2006 | 10:52 AM
yeah that connection is good and tight. And my worse fear is it being a wiring problem.
Old Aug 27, 2006 | 04:21 PM
1991L98G92's Avatar
Here's the flow chart for code 42
Attached Thumbnails code 42-code-42-1.jpg   code 42-code-42-2.jpg   code 42-code-42-3.jpg
Old Aug 27, 2006 | 04:22 PM
1991L98G92's Avatar
Last pic
Old Aug 27, 2006 | 09:43 PM
thats awsome man i appreciate it. I'll run those wires down this weekend. Thanks again
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
