400/t5 starter?
Subscribe
Aug 30, 2006 | 10:34 PM
  #51
OK, so where's my pic??
Let's try this again...
400/t5 starter?-cvr-starter.jpg
Reply 0
Aug 30, 2006 | 10:39 PM
  #52
if i spoke out of line im again sorry but iwas told that the starter would work with the 153 flywheel an heres the catalog i got it from 062114 h the source code on back an mike something at jegs i was just tryin to give an alternative because im there with ya like now not knowing how to create a post
Reply 0
Aug 30, 2006 | 10:46 PM
  #53
idiot your the one that told that poor guy he didnt need to check pinion depth an richmond gear was junk thanks for the help idiot at very least if i was wrong at least it would not have cost him anything this guy must be in a cloud
Reply 0
Aug 31, 2006 | 07:43 AM
  #54
whos in a cloud?
Reply 0
Sep 1, 2006 | 08:11 AM
  #55
look very closely at this pic, it IS adjustable for 153 and 168 tooth flywheels, so you are right there, thats why it has 4 holes. now show me where the bolt hole for the old style blocks is at?
there isnt one, meaning id have to drill my block to use that starter because ALL of those bolt holes are inline.
sprojam, the problem here isnt the starter, its the block, and my limits of what i can do since i have a small bellhousing and a 153 tooth flywheel. i dont think any of these guys are idiots, theyve actually been very helpful
sofa, sonix,
i found the tools at wholesale tool (6 bucks apeice for the bits!) and i bought a 8 inch piece of 3/8 brake line. which had a inside diameter of 5/16 and can be had at any parts store (mine delivered my piece to work!)
i bolted the starter in place and used a straitedge to check the gaps behind each side of the starter in reference to the bellhousing. I drilled 3/8 down with a 3/8 bit, then put the brakeline over the 5/16 bit, and went to town. the hole does look a tad off compared to the other one, but im not sure if thats because the casting on the other bolt hole is different than the other block i measured in the back of my truck. ran the tap through it, bolted it up, and re checked the gaps with my straitedge, which were the same still.
it all bolts in fine no binding whatsoever. i hope this works, or ill just put a automatic back in it and hope for next spring
Reply 0
Sep 1, 2006 | 08:27 AM
  #56
hey thats fine and you guys are prolly right but jegs does have it listed that way on page 139 csr 170-100sbp now the phone call to csr but never mind all that sofaking said onething very important an that hes is using that starter an had to still drill the hole so i was miss lead an there for miss lead you if i have heard all this correctly sorry bout the bad info i thought i had researched it through an another thing is its not my car so it doesnt matter i was just tryin to help peace
Reply 0
Sep 1, 2006 | 09:10 AM
  #57
Randy:
You'll also find that the mini-starter and all that, will fit and work perfect when your T-5 grinds itself up into dust, and you get a T-56. Which is what I ended up doing; I have about a 96 or 97 T-56 in my car now, with the same mini-starter.
Glad you were able to find all the tools and all locally, and get it done. Believe me, you're not the first to end up in this situation, and you surely won't be the last! People just about always find out about it the way you did: motor is in, everything is hooked up, they're laying on their back trying to bolt up their starter, and OOOPS.... what do I do now???
I seriously doubt that you'll find the stock starter satisfactory. Mine wouldn't turn over my 400 more than about 3 or 4 revolutions before it got tired. I got stuck in parking lots on a regular basis, waiting on the motor to cool down to where the starter would spin it (no, it wasn't "heat soak", whatever that would be if it actually existed). I went through more starters and batteries than I care to remember, trying to get it to where it would start hot, especially (the starter couldn't overcome a cyl that fired BTDC); the mini-starter TOTALLY eliminated that. It whirls my 400 over about twice as fast as the stock POS would even spin the original 305.
Enjoy!!!
Reply 0
Sep 1, 2006 | 09:18 AM
  #58
Just a little FYI, GM used a staggered bolt gear drive starter used with a 153 tooth flexplate/flywheel on alot of the Vortec 4.3 S10 trucks.
IIRC, the Autozone Part number is DL9997S
Reply 0
Sep 1, 2006 | 10:05 AM
  #59
i checked on a flywheel and it was 168 tooth for a vortec s10, bigger clutch than camaro also
Reply 0
Subscribe
