EGR Question
Old Aug 28, 2006 | 04:47 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
EGR Question
Without removing my plenum to physically look for the ID numbers on my EGR, is there a way for me to tell what kind it is so that I get the proper replacement when I go to NAPA? I understand there are positive and negative backpressure versions, and that I need to get the right one.
Thanks for your help.
Dave
Old Aug 28, 2006 | 07:47 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i would recommend an EGR valve that is not a pressure type valve.
one that uses either negative or positive back pressure may not work with after market exhaust.
the parts house should be able to look up the right part number for you.
to check the valve to see if it is a back pressure type of valve put a piece of vacuum hose on it & suck on the hose, if it opens that valve should work fine.
Old Sep 2, 2006 | 02:38 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
NAPA is good on the part #'s. Give them the same info in your sig. and you should get the right part. Napa is not cheap, but they get it right 99% of the time. If you don't have any exaust mod's, you'll get the right part. Why are you wanting to replace the EGR valve in the first place? Code 32? You might be wasting your money repacing the EGR valve if the solinoid or vaccum lines are bad. Changing to a cooler thermoustat (lower than 190*) could cause a code 32 also.
Old Sep 2, 2006 | 07:59 AM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
Would this be what you want? It should be a OEM direct replacement.
http://www.napaonline.com/masterpage...on+(EGR)+Valve
Old Sep 2, 2006 | 09:15 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
This is the EGR valve I use on my 87 TA.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
