Car won't start - 15 minutes later it's fine??
Old Aug 28, 2006 | 09:02 PM
USA_Rally's Avatar
Car: 92 Rally
92 Camaro has recently started acting very tempermental. Some times when I go to start my car nothing happens. Then, everytime without fail, it will start 10 or 15 minutes later. It occurs on hot and cold starts. Any known issues with these symptoms?
Old Aug 28, 2006 | 09:45 PM
ybelikeu's Avatar
Car: 1984 Z-28
Engine: 305 H.O.
Transmission: 5 speed
I had a similar problem with my camaro. It was a bad solenoid on the starter. I never tried but I was told that when it would not start to tap the solenoid with a hammer. I found it impossible to wedge myself under my car to get to the solenoid. In your case you could get a tester and make sure you are getting a signal to the solenoid. If you are getting the signal then it is the solenoid if there is no signal then there is a problem upstream. I know that year camaro had the vats system which can also cause starting problems. I would start at the starter first because I don't know how to trouble shoot the VATS system. you are looking for a signal where the small wire is attached to the solenoid.
Old Aug 28, 2006 | 10:09 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by USA_Rally
92 Camaro...It occurs on hot and cold starts. Any known issues with these symptoms?
Wiring (such as loose wire at starter/cables) or VATS problem. That symptom (not even a click) if it was the starter would be worse when it is hot.
Old Aug 28, 2006 | 10:21 PM
whiteshadow87's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 1991 L-98
Transmission: 700R-4
sounds like VATS to me
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
