need head info
Old Aug 28, 2006 | 10:50 PM
fried's Avatar
need head info
can someone give me some more info on these heads:
12551561...96......350..........Gen.II, "LT1", aluminum
are they any good and what are there specs? cant seem to find any info!
thanks
Old Aug 29, 2006 | 09:59 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
i found the following once when i was looking for the same.
1.94 intake
1.5 exhaust
51.9 cc
originally came in 96 300hp chevy 10.4 comp.
they were no good for me because they are reverse cooling.
hope this helps.
Old Aug 29, 2006 | 10:57 AM
Damon's Avatar
Gen II = reverse cooling. No suitable on earlier Gen 1 motors unless modified significantly to work with the earlier Gen 1 standard-direction cooling system. I beleive there are one or two people on the board here who have done it, though- might want to search and ask around.
Those heads were used on 4th gen Camaros and Trans Ams (possibly Corvette) with the LT-1 motor (350 with fuel injection). They were the only LT-1 cars that got the aluminum heads.
Also, the intake manifold bolt pattern is completely different than any other small block. It's not 86-down pattern, it's not 87-up pattern and it's not Vortec pattern. It's it's own separate animal. I beleive GMPP makes a carb-style intake that will bolt to them, however.
Old Aug 29, 2006 | 10:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
really good heads, for somewhat cheap, if you can justify making the modifications.
I know "MeLeigh" has modded them for use on his 305 motor. (some style of LT1 heads, not sure if there many different LT1 heads out there).
There's also another member who made a detailed thread about what mods were needed, along with dyno results I think. I remember this thread because he made the comment he milled the thickness of fly **** off them to get them flat. Anyway that made me remember the thread existed... Maybe you can use that to find the thread.
Old Aug 30, 2006 | 12:27 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC there were 3 different Gen II aluminum castings. There was an earlier LT1 casting for the sub-300hp cars, and a different one for the 300+hp cars. Then there was the LT4 head as well. There's also 2 cast iron heads as well, for the non-performance Gen II motors, like the Caprice got. One for the 5.7, and one for the 4.3(?).
IIRC, the iron 5.7 head actually breathes better than the early LT1 aluminum heads, and the later LT1 heads were about the same or slightly better than the iron heads. The LT4 heads were lightyears better than the LT1s.
Old Aug 30, 2006 | 04:45 PM
fried's Avatar
so its not a simple swap...sounds like to much work for me haha
Cornholio7979
Sep 20, 2018 02:31 AM
gta90
Sep 15, 2015 04:00 PM
509 camaro fan
Sep 6, 2015 10:43 AM
ambainb
Aug 29, 2015 12:43 AM
