what HP/Torque do you think it will make
Old Aug 29, 2006 | 08:49 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
At the rear wheels
305 30 over
flat tops/ close to 10 to 1
roller cam spec.
Basic Operating RPM Range: 1,200-5,200 RPM
Intake Duration at 050 inch Lift: 210
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 210 int./220 exh.
Advertised Intake Duration: 264
Advertised Exhaust Duration: 274
Advertised Duration: 264 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.480 exh. lift
Lobe Separation (degrees):
ported (081 heads, stock intake, upper pleneum) little cleanup on runners
21 lbs injectors
afpr
custom prom
edelbrock tes header and y, 3in cat back
roller tip rocker
matched springs
msd-6a
some other little things, I will post what I think after I hear from you guys
Old Aug 29, 2006 | 10:35 AM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Thats the comp. cams 264 cam. Good cam.In a 350 I would say 280-310hp.This is just a guess. Maybe 240-270hp in a 305 but that might be way to high.Any of you guys with 305's want to throw some numbers in?
Sorry at the rear wheels. 210-235hp.
Old Aug 29, 2006 | 10:31 PM
chevy13's Avatar
Guessing the loss through a auto trans at 15% according to my DD2000 around 249hp and 337tq, but that sounds a little high.
Old Aug 29, 2006 | 10:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ported heads, 210/220 roller cam, 10:1 CR, i'd say higher. Almost 300HP is my guess.
I'd do some porting on the intake if you haven't yet, that's the restriction on a tpi motor IIRC.
Old Aug 30, 2006 | 06:40 AM
jamon8's Avatar
Engine: 350 tpi
Sonix, I ported the intake big time and I do not just mean port match.
I am thinking 245/325 at the rear wheels.
I will be finding out.
the car is not built for racing but I still would like to beat up on the 5.7 GTOs and then tell them they got spanked by a 305
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
