Really bad emission and engine help
Old Aug 31, 2006 | 10:44 PM
TransAm90GTA's Avatar
Car: 1990 Trans Am Gta
Engine: 350 5.7
My 87 305 Iroq has had problems since the day i bought it. I recently brought in to get stickered and they didnt get to the inspection becuase the emission was so bad. My CO2 was a 13.25 out of a 1.10 limit, The HC was a 755 out of 275 and the NO was the only one i passed with a 2595 of 3600. The car also had a high idle since i got it and a puff of white smoke every now and then at start up. The mech put a new throttle body and sensors, I got new plugs , timing set, new O2 sensor, idle turned down, and vaccum check and it did a little bit worse. I finally got a waiver but i still want to know whats wrong cause i want my car to last. If any one has any ideas or has had this it would be greatly appreciated
Old Aug 31, 2006 | 10:54 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well the little puff of white smoke when you start it means your valvestem seals are bad.
Old Aug 31, 2006 | 11:15 PM
camaro25thrs's Avatar
Car: 87 iroc
What is ur a/f ratio? Also what is ur CO? Are you running tpi or a carb. set up? Is it running rough?
Old Sep 1, 2006 | 05:25 PM
Engine: 350 5.7
Its a tpi and the Co is 13.25 . It runs a little rough but not really that noticable
89GTAOz
May 16, 2020 09:31 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
