head gaskets?
Old Aug 30, 2006 | 07:21 PM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
head gaskets?
what usually happens when you blow a head gasket? cause my car is burning coolant
Old Aug 30, 2006 | 07:36 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
what do you mean your car is burning coolant? usually if you blow a head gasket you'll know it oil will spill out onto the exhaust and burn and the coolant could mix with the oil and your engine could get really messed up.
Old Aug 30, 2006 | 07:38 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
If by burning coolent you mean you have steam coming out of your exaust then it is probly the head gasket.
Old Aug 30, 2006 | 08:06 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
If your oil looks like choclate milk, good chance you blew a head gasket.
Old Sep 1, 2006 | 05:43 PM
dark chocolate milk?
cause my oil does look weird now and the steam coming from my exhaust smells like coolant but its really stinky too, it doesnt smell sweet like it should
Old Sep 1, 2006 | 05:46 PM
ianaz116's Avatar
chocolate milk oil, white smoke out the exhaust that lingers and smells sweet... found mine busted yesterday too
Old Sep 1, 2006 | 05:48 PM
how much does it cost to fix?
or should i just take the time to do it with one of my buddies
Old Sep 1, 2006 | 05:55 PM
ianaz116's Avatar
it always depends on the mechanic, but itll be pricy for sure (600?)because it involves a lot of man hours. im going to pull the engine out on mine because i have to do timing work anyway. id suggest you do the same. while youre there you can replace all of the other gaskets. dont forget to change out the headbolts
Old Sep 1, 2006 | 05:59 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It's not really a job for the weekend wrench turner, but you will save a bundle if you and your buddy get together and do it.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
