Blue exhaust smoke
Old Sep 4, 2006 | 07:19 PM
abide70's Avatar
Car: 86Z
Engine: 355
Blue exhaust smoke
I have recently noticed blue smoke from the exhaust,usally at higher rpms when you let off the gas.no smoke is present at startup or under normal driving.The motor is freshly rebuilt 10k ago w/ new sportsman heads.the motor holds 15" of vacuum with the moderate cam it has.So could it be a intake manifold gasket leak,bad valve seals or guides? I was told that intake leaks can be problematic,one person reccommend using silicone on the intake ports too eliminate leaks,seems too me that gasoline would eat the silicone? Anyone have any suggestions TIA Joe
Old Sep 4, 2006 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
blue smoke usually indicates an oil leak, i have never had to silicon the intake runners, and i do believe solicon and gas dont mix, if the motor is new, i may still be breaking in, though you did say it was 10K old.. maybe some crap parts to a dump
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
ericjon262
Sep 11, 2015 06:07 PM
Accerrito22
Sep 5, 2015 09:34 PM
