oil pressure
Old Sep 5, 2006 | 08:17 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
oil pressure
what should the oil pressure be when the oil is at operating temperature. i get about 40 when cruising and about 20 when at idle. i think its a standard pressure pump. the oil is 10w-40
Old Sep 5, 2006 | 08:18 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Your fine
Old Sep 5, 2006 | 09:11 PM
Vader's Avatar
The general rule of thumb for standard clearance bearings is 10 pounds per 1,000 RPM.
Old Sep 10, 2006 | 03:58 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
mine is doing the same thing, at idle it goes between 10-20, but when i give it gas it shoots up to past 40.
is this normal? by the way its aftermarket mechanical gauge.
Old Sep 10, 2006 | 04:22 PM
joe350's Avatar
Car: 91 Z28
Higher RPM turns the pump faster, hence more oil pressure. Makes sense, doesn't it?
Old Sep 10, 2006 | 06:14 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
obviously, im just askin if at idle 10-20 is ok, as say a month again it was constantly at 40, but i had some work done, nothin major, new balancer, timing pointer, rebuilt the carb, new valve covers.. since then oil at idle around 700-800 pressure is 10-20
Old Sep 10, 2006 | 07:16 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
Your oil pressure is fine,that is about normal.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
