replacing head gaskets
Old Sep 5, 2006 | 10:11 PM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
i want to replace the head gaskets on my iroc but im not too sure about it, my iroc has the L98 5.7L, do i have to mess around with the timing or anything to take the heads off and stuff? cause i dont wanna break it anymore that it already is.
plz help thx
Old Sep 5, 2006 | 11:12 PM
j dezzy's Avatar
Car: 87 TA
shouldn't have to mess with timing.
Old Sep 5, 2006 | 11:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
how would you NOT have to mess with timing, considering you have to pull the intake to pull the heads and last time i checked the distributor has to be pulled first.
Old Sep 5, 2006 | 11:41 PM
Brandon Crawfor's Avatar
Car: 1982 Camaro Z28
Engine: 350 V8
Im considering the same thing, being as i have to replace some other gaskets to fix an oil leak, but i was under the impression that you have to have the block and heads machined flat? but i might be wrong, it happens
Old Sep 6, 2006 | 04:34 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If your head gaskets are OK and you're just changing them because you're doing every other gasket, then they won't need machining, but you have to make sure the surface is clean before putting a new gasket on.
If you have blown head gasket + aluminum head, then I'd recommend getting them checked by a machine shop and shaved if necesessary (about $40 per head).
Iron heads don't tend to warp like the aluminum ones. Aluminum has a much lower melting temperature than iron, meaning it warps at a lower temperature than iron will as well.
As far as timing goes, as long as the distributor rotor, and body are clearly scribed to the intake before removal, there shouldn't be any issues when reassembling.
Lifter Preload is a different story. Not bad though.
Old Sep 6, 2006 | 01:44 PM
j dezzy's Avatar
Car: 87 TA
LOL...damn, I didn't even think about that. I even just put new heads on my buddies monte carlo the other night too....it was a late night for me when I typed that....lol.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
MY87LT
Aug 17, 2015 08:43 AM
