K frame drop,engine
Old Sep 7, 2006 | 09:09 PM
gtatech's Avatar
K frame drop,engine
anybody had any experience dropping the engine from a 87 ta from the bottom?
Old Sep 8, 2006 | 07:07 AM
Probably not; since that's not how it's done in these cars. That's not how they're put together, so that's now how you take them apart. Even if you decided to do it like that, it would be several times as much work as doing it the right way, which is a piece of cake.
Old Sep 8, 2006 | 07:45 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's only 6 bolts holding the k-member in so it is possible.
You would have to disconnect the struts and brake lines. Personnally, I think it would be easier to go out the top.
Old Sep 8, 2006 | 08:32 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I took mine out of the bottom. What do you wanna know? There is no such thing as a walk through or any real details. Youjust sotra do it. I had to as the garadge where I am building my car could not fit a hoist in it. Really not that bad at all. Just about everything was out of my car though. I was doing a total 100% rip down. If you wanna JUST pull the motor, go out the top.
Old Sep 8, 2006 | 01:03 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It is how the 4th gens are supposed to come out though, according to the service manual.
But I agree. There may be 6 bolts holding the k-member on,but theres a whole ton of other crap to take off. I've done k-member swaps, it sucks.
-- Joe
Old Sep 8, 2006 | 01:15 PM
Right; 4th gens, and a whole lot of others including FWD ones, come apart that way, where you pull the car off of the engine as opposed to pulling the engine out of the car.
But not these cars.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
