Loss of power while in low rpm
Old Sep 10, 2006 | 02:55 AM
cammed91's Avatar
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
So i just had fastchips burn me a new chip for my car about a week ago and i put it in and it drove fine but today when i was driving it, i was just cruising at around 1400rpm and i went to accelerate and it felt like it was bogging down and would just feel real sluggish until i pushed hard enough for it to downshift. as soon as it would downshift it would feel normal though. it seems like as soon as the rpms raise over 2200rpm it goes back to normal. i was just wondering if this had to do with the programming of the chip or of something else. could it be the fuel pressure? haven't checked that yet but i will tomorrow. just wondering if you guys had any ideas that would help me out. it is just a l98 with a holley stealth ram, with the stock 22lb injectors, msd 6al, shorties, flows, cam w/ springs. its not giving me any codes either.
Old Sep 17, 2006 | 07:13 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Did it do that before or after the custom chip?
Old Sep 17, 2006 | 07:36 PM
cammed91's Avatar
it has just started after the chip
Old Sep 17, 2006 | 10:07 PM
Car: 92 Camaro
Axle/Gears: S60 373
tell the guy who burnt the chip for you what the problem is... he should fix it for you. same thing happened to me when i had custom chip burnt for my hsr wwith headers and cat back. the guy re programmed it and sent it back no problem
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
perZ
Aug 15, 2015 01:17 PM
Bradsaundry
Aug 12, 2015 12:34 AM
