Engine kit
Engine kit
I am having some trouble finding rods and a new crankshaft for my 305, does anyone know where i can get those, or an entire rotating kit. im at the last stage of my 85 iroc build and all i have to do is build the motor. so any help would be apreciated. thank you
Car: 1983 G20 Chevy
Transmission: 4L60
I know, I know, it is a 350 shortblock. But at the cost with the warrenty you can barely rebuild the 305 for that.
12605117 -GM Performance Parts 350 Partial Engine (Shortblock) Used With 10067353 (Universal 350) & 12499529 (290 HP Engine) - 12605117
Its built with the same Nodular iron crank and PM rods that come in the LT1 and early ZZ4s.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The 350 upgrade is the obvious choice, but i'm sure summit would have an eagle rotating kit or the like ready to go. You can use 350 rods and crank, then just have it balanced to the 305 pistons. Removing material from the crank is what would be necessary i'd think, so that's relatively inexpensive.
Ohio crankshaft, powerhouse, any of those other places that advertise in the back of hot rod or super chevy or car craft would have a kit.
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
