MPG??
Old Sep 13, 2006 | 12:06 PM
alxtre99's Avatar
Car: 91' Camaro, 71' MERCEDES
Engine: Camaro 3.1L
MPG??
almost at 140,000 on the ol' LG4 now and i was wondering what my MGP are at cause im about to head on a road from southern cali to denver colorado. The only mod's are a open element air cleaner with an airhog high flow air filter, 3" high-flow cat, 3" mid-piping, and a 3" single in / duel out flowmaster......... any ideas?!?!
Old Sep 13, 2006 | 03:37 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Yup...
1. Fill up the tank to the top.
2. Reset trip odometer. If its broken, record actual odometer milage.
3. Go drive granny-like until about 1/4 of your tank is left.
4. Fill up to the top again. Use the same station, even the same pump if possible for the most accurate results.
5. Time for math... Milage on trip odometer divided by gallons needed to fill it up equals MPG.
6. Don't forget to reset the milage so you can measure again on the next tank.
7. For a more accurate number, repeat 5 times and average results together.
Nobody can guess your milage. The amount of variables, including how you drive, condition of engine, and current state of tune makes it impossible to lay down a flat number of what you will get.
The gearing(which apparently your to lazy to figure out) in your axle is another of the dizzying amount of factors.
I've got an LO3 with 176,000 and similar mods as yours. I get about 20 mpg combined. And I've got a pretty light foot in that car. I gotta save my gas money for flooring the other, faster car.
I'd be shocked if you could break 23mpg. But that's just my opinion, its possible to do better, but not easy.
Old Sep 13, 2006 | 03:39 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
20 mpg is what I get on the highway at about 80 mph.
Old Sep 16, 2006 | 01:52 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
MPG
Burn reg. gas. New plugs, 70-80 MPH. 22 + mpg. Highway. That's what I get, And my cruise doesn't work.
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
James Sutton
Sep 23, 2015 02:18 PM
ssgt usaf
Sep 21, 2015 12:45 PM
