LS1 Heads
Old Sep 14, 2006 | 06:51 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
LS1 Heads
I have a 92 Firebird 5.7 and I'm trying to put together another motor. I found a set of new LS1 heads for sale and was curious if these would work with the TPI setup, and a block from 1987-1992? Appreciate the help. Would these give me any more performance over the stock heads on an L98? Thanks
Old Sep 14, 2006 | 07:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
They won't work. LS1 and a gen 1 small block like your L98 are two totally different animals.
Old Sep 14, 2006 | 07:11 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Could you recommend anything? Right now I'm looking for heads and a camshaft. I'd like to get in the range of at least 350hp. I'd appreciate any help. Thanks
Old Sep 14, 2006 | 09:05 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Methods of getting to 350hp will vary depending on what kind of motor you are working with here. Enlighten us as to your setup, and youll get some response.
Old Sep 14, 2006 | 09:49 PM
Air_Adam's Avatar
I'd suggest looking at other posts on here that show what others are using with TPI setups, to find out the pros and cons of whats out there. The most popular stuff seems to be AFR, TrickFlow, and Dart heads in the 180-200cc range, with 64cc chambers, but I'd suggest you look around on the board a bit, use the Search function, and find out how you want to make your power (naturally aspirated, nitrous, supercharger?) and what heads the others seem to like for a similar setup to what you want.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
