cam installed, few questions
Old Sep 18, 2006 | 12:21 AM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
i just finished putting an LT4 hot cam in my L98. i took it for a test drive today, and it seemed like if i tried to get on it a little bit that all it was doing was reving up and not really moving me anywhere. kinda like on a standard when the clutch is going out. any ideas what this could be?
what i did was: complete rebuild on the motor, LT4 hot cam, changed tranny fluid/filter. i also put on a plate nitrous system which moved the throttle body 1/2 inch forward. any input will be appreciated, thanks.
Old Sep 18, 2006 | 12:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure the transmission is filled properly?
Old Sep 18, 2006 | 02:57 AM
ede's Avatar
ede
are yuo sure the filter is installed correctly and the old o ring removed?
Old Sep 18, 2006 | 01:19 PM
Car: 89 Formula
Engine: 5.7 TPI
i didnt know there was a "proper" way to fill the transmission, i just dumped the oil in it...
the filter is in correctly, and yes i pulled the old o ring out, it came out on the old filter.
Old Sep 18, 2006 | 01:56 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
how many quarts did you put in, did you overfill the tranny?
Old Sep 18, 2006 | 03:03 PM
Car: 89 Formula
Engine: 5.7 TPI
i dont remember how many quarts it took, but its not overfilled, i already checked that.
and i already adjusted the TV cable, i havent driven it today, but i rolled it around the driveway. last night when i put it in gear it wouldnt go anywhere without giving it gas, today i just let off the brake and it was fine.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
