ok now i cant move my car
Old Sep 18, 2006 | 07:49 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i just got done installing a 406 in my iroc which originally was a 305/5spd. I retained the 5speed, but had to install a 1/8 thick balancer plate to acommodate teh 400 (externallybalanced) with the neutral balanced 305/350 flywheel. everything else trans wise is stock new slave and master, and bled, and bled, and bled, and bled
I cannot disengage the clutch. I can start the car in gear, but it wont come out of gear and the car barely tries to move. is the clutchassy moved farther back into the trans affecting teh function of the slave cyl? do i need a shorter pushrod since the fork is pushed closer to the slave cylinder and the stock length rod is putting pressure on the slave? i installed a 1/8 longer rod and had no affect on the condition
help please, i want to drive this thing, its been too long
thanks
Old Sep 18, 2006 | 08:29 AM
I doubt that the "pork chop" weight is causing the problem.
Which way did you assemble the throwout to the fork?
Old Sep 18, 2006 | 08:38 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i did not remove the throwout bearing from the fork, everything except for the flywheel and the 1/8 inch spacer/counterweight for the crank arre different. everything else is the same. still got the same clutch and all that was originally in the car.
Old Sep 18, 2006 | 08:55 AM
What kind of pilot bearing or bushing did you use in your new crank? Did the trans fit into it gracefully?
Old Sep 18, 2006 | 09:20 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
stock pilot bushing, and the imput shaft was greased before installation,
slid together just fine
Old Sep 18, 2006 | 09:21 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
its gotta be just barely engaged because it barely moves the car when started in gear.
Old Sep 18, 2006 | 02:04 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
anybody have any ideas?
BlueIroc-Z
Jun 9, 2019 03:22 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
