Cracked Water pump pully?
Old Sep 18, 2006 | 07:14 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Cracked Water pump pully? With Pictures...
Ok guys,
I've got what I consider a serious rattle when my engines running. I believe it's coming from the water pump but I'm not sure. ANYWAY...while inspecting the belts and bolts, I noticed a crack that runs from the wall of the number 2 belt groove, down through the valley and up the other side. This can't be good can it? I've personally never seen a cracked pully like this before. Have any of you?
Old Sep 18, 2006 | 08:01 PM
MikeS's Avatar
Are you sure that's a crack? I can't remember for sure, but there might be a seam in that pulley?
You may be hearing a water pump on its last legs...
Old Sep 18, 2006 | 08:42 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Well, I guess it's no time like the present for a new water pump and pully... well, water pump at least. ONce I get it apart I can see if I need a new pully also.
Old Sep 18, 2006 | 09:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
no no, pulleys don't crack, that'd be the first one i'd have seen as well.
Remove all belts, and start up the car briefly. If the rattle is gone, then you're right, its an accessory, maybe the waterpump. I have a funny feeling you'll hear its still there though....
Old Sep 18, 2006 | 11:02 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Well, check out this picture...
This one you can see, just up from the bolt you'll see a line below the head of a flat-head screw driver. That's the crack. More pictures below
http://strike9.com/file.ashx?path=/m...t/100_1302.JPG
Here is another picture. Just up from the bolt head you can see the crack.
http://strike9.com/file.ashx?path=/m...t/100_1303.JPG
I've never seen anything quite like it but the crack starts on the top inner most wall of the number 2 belt groove, travels down the valley and is starting up the other side.
Old Sep 19, 2006 | 12:10 AM
Sonix's Avatar
Car: 1982 Trans-Am
well, that is weird, but I don't think that's the source of your sound.
But, only way to be sure is to remove all your Vbelts, and find out. You can run your car without power steering, alternator, or water pump, for at least 10 seconds without causing any harm, and that should tell you if the sound is there or not.
Old Sep 19, 2006 | 07:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Aye. Tonight after work I'll pull the belts and see what I can come up with. The problem is down here, finding a new pully. THere aren't any Trans Am or Camaros in the yards here to pick apart. I might end up buying a "Gulp" new one from Chevy.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
