Stock 91 Firebird GTA differential ?
Old Sep 18, 2006 | 11:18 PM
A_Frame's Avatar
Im curious to know waht kind of differential is in a 91 TA GTA. I have seen several videos of ppl dooing 1 wheel burnouts and others using all the rear rubber.
Old Sep 19, 2006 | 12:13 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
probably a stock auburn posi with a 3.23 ratio.
Check the stamp on the tubes, and look for a metal tag which will say what it had factory. Theres a link on the main page of TGO to help decode the link. Of course, in the last 15yrs someone could have easily swapped it so...
Old Sep 19, 2006 | 10:52 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Or it could be a posi like the one in my '91 GTA... One tire fire, because its completely worn out... I've got a new auburn one with some new gears waiting though...
Old Sep 19, 2006 | 06:24 PM
A_Frame's Avatar
So your saying Posi will only let 1 wheel slip ?
Old Sep 19, 2006 | 07:15 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
If the clutch packs are worn to the point where they can no longer do their job yes.
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
red90IROCls1
Aug 25, 2015 06:56 AM
gta power
Aug 13, 2015 06:15 AM
Randomtask2
Aug 13, 2015 01:57 AM
