Oil pressure sender
Old Sep 20, 2006 | 01:06 PM
88TTFB's Avatar
Car: 88 TA
Engine: 5.7 TPI
Oil pressure sender
Im sure someone knows the answer to this. Is there an oil pressure switch that has a pressure sender built in? Like a 3 wire version. I have the big bulb mounted by the distributor and I would like to eliminate that. I want to use that for my Oil feel to my turbos. I dont want to remote mount that sensor if i can get a combo switch/sender. Thanks
Old Sep 20, 2006 | 04:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes
Old Sep 21, 2006 | 12:07 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
there's also usually a provision in the front of the block just above the timing chain cover on the passenger side that can be used to test oil pressure. most of the time you can use the one down by the oil filter too if you can route wiring/hoses around the exhaust.
Old Sep 21, 2006 | 10:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That one's only on the older blocks. Newer ones don't have it.
Old Sep 25, 2006 | 09:09 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Don't have what? My 88 has ports in all 3 places but it's a 5.0. (just curious).
Old Sep 25, 2006 | 10:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not all the later blocks have the oil port in the front drilled and tapped.
Old Sep 25, 2006 | 01:02 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
NO SHEET? I was totaly unaware of that! Next time I go the the salvage yard I'm going to pay more attn. Thanks
Old Sep 25, 2006 | 02:56 PM
Car: '85 TA
Why would they do that on some blocks and not others? We don't use them for anything that I am aware of, so why would they put them there in the first place?
Old Sep 25, 2006 | 04:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As far as I know, they were used originally for the optional partial-flow oil filter setup on the very first SBCs.
Apart from that, they're a pretty convenient place to temporarily put an oil pressure gauge, that's about it.
Old Sep 26, 2006 | 02:26 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Temporarily? Oh crap, I've had mine in for year's! Now what am I goin to do? Seriously though, I like to think that GM gave us speed freaks an option to mount manual gauges! so we wouldn't have to hack up the original wiring harness.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
