TPI to carb questions....
Old Sep 20, 2006 | 05:44 PM
slow83sc's Avatar
Car: 83 camaro sport coupe/ 1981 Camaro
Engine: 2.8 2bbl
Transmission: thm200c
I'm deciding whether to purchase this from a buddy of mine or not. He has a 350 TPI longblock out of a 88 GTA and I was thinking of putting my carb and intake on it. I made him take the block off plate off of the engine and see if it is drilled for the fuel pump pushrod and it is, and I also made him check to see if it has a fuel pump lobe on the cam and he says it does. My main question is this, I will be using an old school HEI distributor and I want to know If I need a special gear for it, or can I keep my stocker, it's in great shape. I know about the centerbolt issue with the intake and I already have the right intake.
Thanks in advance guys!
Old Sep 21, 2006 | 12:04 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i've had both the small computer controlled and large cap HEI ignitions in my current engine, leading me to believe that they are identical from the intake seal down.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
