L03 hiccup. Need help troubleshooting!
Old Sep 22, 2006 | 12:55 PM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
My L03 Camaro has developed a bad intermitant ''bog'' or ''hesitation'' at idle and under part acceleration. It feels like it's dropping voltage, but the guage reads normal (no fluctuation) when it bogs. I put on a remanned autozone alternator a month ago that reads 10.5-11 volts half the time, but this problem has developed recently. It's throwing a code 53, don't know if that could cause this kind of problem.
Old Sep 23, 2006 | 09:55 AM
Vader's Avatar
Anything under 12.8V running is a problem, and may be creating problems with the control system.
Old Sep 24, 2006 | 03:04 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
mine does the same but i have underdrive pulleys and by the time it bogs the gauge is at the normal, could it be a fuel pump?
Old Sep 25, 2006 | 08:51 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Assuming you got a 110 amp alt or better, next time it get's the hiccups, watch your tach. If it just dies and comes to life again check the wires from the external coil and make sure they aren't arcing. Make sure the're not touching each other. I had a problem simular to yours and my finger found the problem! (ouch).
junior419
Apr 7, 2025 11:35 AM
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
anesthes
Sep 21, 2015 10:24 AM
Sharpcorner
Jun 14, 2001 12:58 PM
