Wierd Problem
Old Sep 22, 2006 | 09:38 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Wierd Problem
I have never heard of a problem like this. I usuraly start the car and let it run for a little wile to warm up. After i drive it for about 5 to 10 mins it dies and takes me 5 mins to get running again. After that it runs fine and dosent die at all.
I know it is a fuel problem. I had the gastank flushed and put a new filter on when i put the motor in. Do you think its a cloged filter or is my mechanical fuelpump going bad?
Old Sep 22, 2006 | 11:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
easy way to check - after it dies, when it takes 5 mins to restart - disco the fuel line at the carb or block pump - and get someone to crank it, see if fuel is pumping there. Possible vapor lock or bad pump or something.
or choke setting?
that kinda throws me actually...
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
