Camaro will not start at running temp
Old Sep 23, 2006 | 08:39 AM
skiluv4's Avatar
Car: 1989 IROCZ, and a 1970 Opel GT
Engine: 350TPI-L98
Transmission: 700R4 w/shift kit
When my camaro gets to running temp at 210 it will not start again until it cools down. I was told that GM starter's do that before they go bad but the starter is only 4 years old. I would hate to start replacing stuff that is still good.
Old Sep 23, 2006 | 09:10 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
If the car is turning over but not starting, then it is not the starter motor.
If it's not even turning over when the key is turned then it may well be heat soak which is affecting the starter solenoid. If your car has headers, it's far more likely.
Try and (safely) rig up some kind of shield to temporarily place between the starter and the exhaust. Just a flat piece of metal should tell you, the more reflective the better, as you'll see improvement if nothing else. If this is the cause, then you could always buy some exhaust wrap to try and keep the heat in.
Old Sep 23, 2006 | 09:37 AM
skiluv4's Avatar
Engine: 350TPI-L98
It does not turn over and it doesn't have headers. It doesn't even get a selenoid click. I will try the metal shield in a couple of hours. Let my neighbors wake up first. Where can I get exhaust wrap? Thanks for the help.
Old Sep 27, 2006 | 02:52 PM
si_camaro's Avatar
Car: 85 Z28
sorry, I don't know where you can get exhaust wrap as I'm in the UK. I've heard a shop called Autozone mentioned on here frequently though, maybe they'll do some.
Old Sep 27, 2006 | 06:26 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by skiluv4
....I was told that GM starter's do that before they go bad but the starter is only 4 years old. I would hate to start replacing stuff that is still good.
Is this a 4 year old rebuilt starter?
Old Sep 27, 2006 | 06:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you're not even getting a solenoid click, it has nothing to do with "heat soak".
I'd look for loose wires, bad connections, etc. But most likely it's just a faulty starter/solenoid.
A nice new ministarter sounds like it'd fit the bill
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
