timing
Old Sep 23, 2006 | 11:28 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
timing
If I advance or retard the initial timing on my car, will it offset the timing on a custom chip? Reason I ask is because I am running 14.6 at 92 mph. My mods are in my sig and I know I am missing power somewhere. But when I dynoed my car it is making 200 hp and 250 torque. Also if I mess with initial timing, wont it mess with the air/fuel ratio? My ratio is dead on. Thanks in advance.
Old Sep 24, 2006 | 12:05 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Adding more initial timing will just add that much more timing through the entire curve. IE - add 2* more inital, you'll have 2* more at 2000, 2* more at 3500....
Old Sep 24, 2006 | 11:55 AM
Car: 92 Camaro
Axle/Gears: S60 373
so would you advise me to mess with the initial timing or no?
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
