timing and egr question.
Old Sep 27, 2006 | 03:36 PM
ryanz53's Avatar
Car: 84 Camaro
Engine: 81 oldsmobile 307 5.0L
Transmission: 700r
Axle/Gears: 3.75
Hi there.
My car is 1984 camaro, 5.0L
I am wondering what would happen if I plug my distributor into the ported vacuum port for the egr valve and leave the egr valve unplugged.
I got a new thermostat housing (chrome) with no timing retard swithe on it.
Thanx.
Old Sep 27, 2006 | 05:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
your distributor has a vacuum port on it?
Is this the stock setup? What country are you in?
EGR unplugged completely, will kill highway mileage 1-2MPG, but that's basically it. You can use a "T" on the ported port on the carb, and run the dist and the EGR off it.
Old Sep 27, 2006 | 11:03 PM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
Yes my dist has a vac port on it.
Acutaly the motor is a 307 from a 1980 olds ( Canadian ).
My main question is. what effect will I get with egr vacuum off or always on ( non ported vac ).
thanx
mdtoren
Aug 23, 2015 12:52 PM
Bryan F
Aug 18, 2015 02:28 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
wruiz
Aug 13, 2015 09:07 PM
