fire extinuisher
Old Sep 29, 2006 | 03:08 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
fire extinuisher
i bought a kiddie fire extingusher for garage and kitchen use. its a 5b/c rated one it says it works for gas and flamable liquids. will this dry chemical extinguisher actually put out the flames or would it be better to run before the car explodes.
Old Sep 29, 2006 | 11:11 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I was talking to my resident OG the other day about this. He's a retired firefighter. From what I gather, it'll put the fire out, but the powder witll make an absolute mess of your car. He was saying that he used to use CO2 extinguishers in his personal cars. Apparently they don't work as quickly as chemical extinguishers, but they don't trash your car with powder.
Old Sep 30, 2006 | 12:26 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Yep, on CO2 fire extinguishers the only thing that comes out in solid form is dry ice, which would eventually just sublime into the gaseous form. In dry chemical extinguishers, the ammonium compounds and others are a real pain in the butt to get out of anything. However, I did find out if you take one of those to the face, you're down for the count. May be an option if there is someone trying to attack you in your car.
Old Sep 30, 2006 | 12:50 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
If you really worried about a fire in your car I would say put in a haylon fire system in your car. While they are expensive (anywhere from $350 to $750) you won't have to watch you car burn up in flames. They also do not leave any mess. I am sure that anyone who has ever tried to clean up a dry chemical fire extinguisher know that the mess is pretty much for ever. CO2 is a great choice for people that can't afford a haylon one.
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
