Funky idle
Old Sep 29, 2006 | 07:42 PM
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
Funky idle
Ok, I have a speed density L98 aluminum head motor in a 1969 Nova. You guys helped me out before and now I have a new issue. I have an Idle issue that occurs intermitintally. The car will bounce between 600 and 100-1200 RPM, with cycles occuring every couple of seconds. This problem will occur and go away during the course of a drive. It does the same thing when it is cold or hot, though the engine wants to and occasionally does stall out. There are no vacuum leaks that I can find. Any help would be most appriciated. Also, what's up, TraviZ?
Old Sep 29, 2006 | 08:54 PM
yzinger1's Avatar
Car: 1991 transam,gunmetal,t-tops,
Engine: 305,.030,k&n,airfoil,3inch exhaust,flowmaster80
Transmission: 700 r4
Axle/Gears: 4:10 posi unit
check voltage at the tps sensor ,also check egr valve ,jimmy
Old Sep 29, 2006 | 08:55 PM
yzinger1's Avatar
check voltage at tps sensor also check egr valve,jimmy sorry for double post
Old Sep 29, 2006 | 09:22 PM
carguy502's Avatar
Car: 1969 Nova
Non-functional EGR, though it is not blocked off. I will check the TPS.
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
