specs of 96 vortec 350
Old Sep 30, 2006 | 07:04 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
does anyone know the specs of a 96 vortec 350 i have one in 92 z28 and wanted to know the specs
Old Sep 30, 2006 | 07:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what spec(s) were you looking for?
Old Sep 30, 2006 | 07:52 PM
Axle/Gears: G92
horsepower torgue rwhp
Old Sep 30, 2006 | 09:34 PM
Axle/Gears: G92
someone please help me on this
Old Sep 30, 2006 | 10:44 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Do you have the fuel injection and everything from the '96 Vortec 350, or did you put TPI on it?? Did you use the vortec heads and get a new TPI baseplate, or did you put standard heads on it?? All of these things affect the output of the engine.. More details are needed...
Old Sep 30, 2006 | 10:46 PM
Axle/Gears: G92
when i got it i was told it had the tpi added on which it still does and it still has vortec heads the only thats not orignal is the tpi everything else is stock
Old Sep 30, 2006 | 10:48 PM
thirdgen88's Avatar
Car: 1995 Corvette
You can look here and see what SDPC got out of a vortec longblock with TPI..
Vortec TPI Intake Baseplate - Scoggin Dickey Parts Center
Old Sep 30, 2006 | 10:52 PM
Axle/Gears: G92
thank you that was very help full... does anyone know any cheap things to get more hp out of this engine? or what years they were made?
Old Sep 30, 2006 | 10:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If it still has the Vortec Cam it is TINY. The same as the B-body LT1. A nice LT4 non Hotcam would liven things up some. Even though the vortec heads flow well, some exhaust porting would really help. The compression ratio is already around 9.4:1 on the vortec, so there is not much to be gained there.
Edelbrock makes some NICE aluminum ETEC heads for the Vortec engine.
The Vortec 350 was produced from 1996-2002 and is still in production for Mercruiser Marine and Volvo Penta as well as for an industrial engine.
The stock HP ranges from 245-255 and torque from 330-340 ft/lbs. In most applications Peak HP was reached at a low 4,600 rpm and peak TQ reached around 2,800.
The camshaft specs are
Hydraulic Roller
191/196 @ .050
.418/.430" lift
111 LSA
107 ICL
Old Sep 30, 2006 | 11:00 PM
Axle/Gears: G92
how much will a hot cam cost? were do they sell the edlebrock heads? aslo you said the horse power was 245 to 255 is that with or without tpi
Old Sep 30, 2006 | 11:04 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You do NOT want the Hotcam. Beside the fact that it was produced for a LT4 which had much better headflow and a hell of alot better intake. It has TOO MUCH LIFT for stock vortec heads. You will have to cut down the valve guide bosses for guide to retainer clearance. The PRODUCTION LT4 cam has less lift and less duration.
Old Sep 30, 2006 | 11:06 PM
Axle/Gears: G92
how much will this increase hp? also if i change the heads which would be the best if it has to much lift?
Old Oct 1, 2006 | 08:38 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Stock Vortec trucks were rated at 250-255hp and 330 ft lb torque or very close to it.
Would almost make a factory replacement long block for us lol
later
Jeremy
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theurge
Aug 21, 2015 12:46 PM
