Crazy problem...
Old Oct 1, 2006 | 04:17 AM
Crawforj's Avatar
Crazy problem...
Car wont start, starter doesnt even try to engage, there isnt a click sound. My fuses are all good, new starter which tests good, new alternator, ignition solenoid, ignition switch, distributor... I havent touched the transmission so I dont know if it could be the neutral safety switch... I get auxillary power though?... Whats the deal does anyone have any ideas?
Old Oct 1, 2006 | 05:10 AM
JesasaurusRex's Avatar
#1 check ur battery, #2 check voltage at ur neutral safety switch
Old Oct 1, 2006 | 07:43 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
, also, check the connections on your battery.
Old Oct 2, 2006 | 12:46 PM
Crawforj's Avatar
Replaced the neutral safety switch, and checked battery, its all good... Could I have put the ignition switch in wrong? It feels tight and it kicks back good though... Are there any fuses leading from the starter to the safety switch? Maybe the wire got fried? Before all this the starter got stuck engaged for a good 2 minutes...
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
