Assembling the Bottom End, Plastiguage?
Old Oct 1, 2006 | 09:44 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I am putting together my first engine and I was planning on using Plastiguage to check my bearing clearances. A firend told me that Plastiguage is unreliable and I need to have it done by a professional. The crank and bearings are new, so I did not think it would be a problem. Is plastiguage sufficient to reliably check bearing clearances?
Old Oct 1, 2006 | 09:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Plastigauge isn't the greatest, but hundreds of thousands of engines have been rebuilt with it. Certainly it's better than not checking clearances at all.
Old Oct 1, 2006 | 10:20 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
If you were to take it to a shop they would probably use plastigage anyways unless your paying a lot of money for machine work. I would invest in a nice set of inside outside micrometers as well. I shown by my engine builder that is you put a single sheet piece of paper in between the crank mains and it locks the crank then your clearances are close enough. Has always worked in the past! just my
Old Oct 1, 2006 | 10:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I built my motor with plastigauge. The green stuff... It should show .0025" or thereabouts. Its a good sanity check. If everythings new, you shouldn't even need it, but to confirm you're in the ballpark, it'll do the job.
If/when you decide to build more motors, get yourself a micrometer set, and a bore gauge.
Old Oct 2, 2006 | 02:46 AM
ede's Avatar
ede
plasti gage is a good way of getting around doing it the right way. like was said there's a very good chance you won't have a problem at all and if you do plasti gage ought to catch it. on the other hand you're asking it to catch the differance in very small variations in clearance.
theshackle
Mar 5, 2017 06:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 21, 2015 07:20 PM
