still having problems
Old Oct 6, 2006 | 06:22 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well my car has had a surge since i bought it so i set minimum idle and cleaned and adjusted iac and it still has a surge im thinking i should adjust tps since its the only thing i havent done. But i dont kno what to use as a jumper wire to connect the connector and sensor together also i dont get how something that is bolted on volts could change. also i noticed when driving my car the voltage surges too and when my voltage goes down so does my idle then the voltage goes back up and so does my idle.
Old Oct 10, 2006 | 06:39 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
tps was set at .60 volts now its back to .54 volts still surges i guess the next step is the voltage regulator.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
