Intake leak, head gasket, or ????
Old Oct 9, 2006 | 09:26 PM
mbrownone's Avatar
Car: 3rd Gen Trans Am
Hi, just removed my intake and cleaning my engine bay when i found this thick milky stuff in a small area in the block. Think it may be coolant from a leak somewhere, but hoping otherwise....what do you think? its not much, but it surprised me. Could this be from just an intake gasket leak (intake gaskets replacements were the original reason i took it apart). Thanks for your comments.
thought i uploaded a pic i took of the spot. but i can email it to someone if you need to see it. thanks again.
Old Oct 10, 2006 | 07:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Milky oil is typically water/coolant in the oil.
Were you trying to link the photo from your computer? Try uploading it instead (assuming it isn't too large), or link it from a public-accessible site.
(Colorado???)
Old Oct 10, 2006 | 07:46 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
if you didn't tear the intake gaskets when you pulled the intake you should be able to see where the water was coming from. it will most likely be at the back of the engine. if it is water/oil it will be a beige color. you can check cylinder pressure to test for leaks there.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
