oil pan stripped out
Old Oct 11, 2006 | 06:57 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
The old owner of my car stripped the oil pan out. I had to loosen the drain plug with a breaker bar all the way to the last thread. When i filled it with oil and tighten the plug i can only do it finger tight and i have sillicone around it to prevent leaks. Well it leaks and now its getting worse i have to add 1/2 quart every 2-3 weeks. My question is do i have enough oil pan to rethread the hole and put and oversized plug in there? how much would this cost me at a shop to do?
Old Oct 11, 2006 | 09:05 AM
Go to a parts store and pick up an oversized "repair" one. You don't even have to thread anything; they're self-tapping. $2, done.
Old Oct 11, 2006 | 08:25 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
when you do buy one remeber they should only cost 2-3 dollars. i went to auto zone and they were 7.99 then i went to fleet farm ( a hardware store with pretty much everything you need in it, i think only in the midwest area though)
and they were only 1.99. i used the one size up then had to move the the 2 size up and still stripped mine out even more, had to spend the weekend pulling the pan off and trying to hoist the engine up to get it past the oil filter. such a nightmare!
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
