header question..
Old Oct 13, 2006 | 08:24 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
header question..
I put some Hedman hedders on my 86' berlinetta some time ago, and now i'm getting to the point where i'm putting everything back together. I was just wondering if all the mounting brackets will still fit with the new headers. Also, i was wondering if anyone had some pictures of the v-belt/mounting bracket configuration for the motor.. any help would be greatly appreciated.
Eddie.
Old Oct 13, 2006 | 11:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You'll need to screw with the power steering mount. One nut goes onto the exhaust manifold stud, front, drivers side. Since your headers don't use that, you can do like I did, and use some threaded rod, and a nut to hold the header on, then another 2 nuts to mount the power steering pump bracket in place, about 1" further out on the threaded rod.
Here, I'm pretty sure my old thread will help you out:
https://www.thirdgen.org/forums/tech...light=brackets
oh, heed the note about the smog bracket bolt (!)
Old Oct 14, 2006 | 10:03 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
found it
yay
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
