Timing Marker
Old Oct 14, 2006 | 08:49 AM
87transamTtop's Avatar
Car: 1987 Trans Am
Engine: LG4 (I desire a 383)
Axle/Gears: Stock?? 1.0? :)
Timing Marker
I can't seem to find the timing plate with the degree markings on it. The only thread I found that was somewhat useful was the one where it indicated that it may have fallen off.
When looking at the engine from the front bumper, can someone tell me where the plate should be locate on LG4 in '87 T/A? Should it be easily visible looking down at the pulley? If I have a general location to look, left, right, under, behind, remove gas tank and transmission to access a bold that needs to be removed so that the timing marker is visible behind the head after removing the engine...
Also, in the event that I'm just stupid and it did fall off, how do I go about replacing it?
Old Oct 14, 2006 | 11:01 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The mark would be on top of the harmonic balancer, did it fall off I doubt it, try cleaning that area.
Old Oct 14, 2006 | 11:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think he's looking for the timing comb, not the timing mark on the balancer.
If your engine is stock, it will be welded to the timing cover.
Old Oct 15, 2006 | 01:40 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Look either down at 2 O clock on the balancer from the drivers side front corver, or behind the water pump. Should see something.
Old Oct 15, 2006 | 05:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
IIRC it's the 12 o'clock position on the 305's (looking behind the water pump)
Old Nov 25, 2006 | 10:32 AM
Car: 1987 Trans Am
BTW, finally found it, it was no where near where i was looking. Have to look straight down from the top. Kind of a pain to see, but it's there. Thanks for the help
Fronzizzle
Aug 17, 2015 02:52 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
