heads
Old Nov 23, 2006 | 11:26 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
heads
any thoughts..in my price rance. will they fit. give opinions plz
Old Nov 23, 2006 | 11:33 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Dude you really have to give us more info than that. How am I supposed to know your price range? As for fitting start searching for heads on summitracing.com via your make model and year and you will get results. Basically anything that is for a 5.7 chevy will fit.
Old Nov 24, 2006 | 10:47 AM
dave-92gta's Avatar
oh sorry
link didnt work haha yea moron --->(me)
here it is
http://cgi.ebay.ca/ALUMINUM-HEADS-NE...QQcmdZViewItem
Old Nov 24, 2006 | 12:21 PM
Just realize that after shipping and the spring kit they provide, you will be shelling out $940 for a set of vortecs. The one plus is that they are aluminum, but at that price I would just rather get a set of Trick Flow heads or Brodix heads for the same price.
Old Nov 24, 2006 | 12:30 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
.....And a Vortec head will not match up to the standard SBC base intake. You need to do more research....
Old Nov 24, 2006 | 02:34 PM
BadSS's Avatar
For the money the Canfields are hard to beat if you want to run them out of the box at $1030 plus shipping (.560 lift).
http://www.competitionproducts.com/p...p?number=200PK
If you could see yourself taking these apart and doing a little port clean-up, a trusted friend of mine with a lot of flowbench times thinks they're the best bang for the buck aluminum head going right now for a "typical" street build up at $880 plus shipping.
http://www.competitionproducts.com/p...?number=300102
Old Nov 24, 2006 | 10:37 PM
Forgot about that one, $400 right there.
Old Nov 24, 2006 | 10:44 PM
dave-92gta's Avatar
all those heads are 2 times as expensive. plus i have been hearing that springs that come with after market heads usualy suck or dont fit your cam combo so you have to get them rebuilt with new springs anyway. as far as the new intake. i was looking at getting the edelbrock base for vortecs. i have a ported plenum and slp runners with a 58 mm tb.
Old Nov 24, 2006 | 11:56 PM
No they arent, again, you have to realize the ones you pointed us to on Ebay are BARE CASTINGS. After you got valves and springs and seals and retainers, you will be out nearly 1000$. The Kenny Duttweiler aluminum heads are just shy of 1000$ or just a little over (depending on the springs you opt for) and the Brodix IK series are short of 1000$.
And as far as the springs being right or wrong for your cam, get the specs on the springs that come with the heads and see if they match the reccommended springs for the cam. Alot of times this can work out...it did for me.
Old Nov 25, 2006 | 11:49 AM
vwdave's Avatar
I found a set of new bare AFR 195's CNC ported on ebay for $800. $700 for misc junk and I'm ahead of the game. Keep looking. If you cant come across a good deal, get some Trick flows from summit. $1100-$1400 depending on options.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
