Shaft mount roller rockers
Old Oct 15, 2006 | 03:10 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Will shaft mount roller rockers clear center bolt style valve covers.
Old Oct 15, 2006 | 03:29 PM
ede's Avatar
ede
i'd think if you were buying them you'd also be buying heads, and matching valve covers, not using stock pieces. WAG i'd say no
Old Oct 15, 2006 | 04:52 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Yea I have AFR heads and 89 corvette valve covers I payed 180 bucks for and would like to keep them for that stock look.
Old Oct 15, 2006 | 05:49 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I don't recall seeing a center bolt shaft system while I was looking.
I'm with ede.
Old Oct 15, 2006 | 07:54 PM
Guest
Guest
Posts: n/a
Got any pictures?
Old Oct 15, 2006 | 11:03 PM
sixpackmtrspts's Avatar
no
Old Oct 16, 2006 | 02:45 AM
ede's Avatar
ede
jensel makes shaft mounted rockers and without looking i'd supect they make one for a SBC, but when i said after market heads and valve covers i was thinking more like brodix. an AFR head is more or less a stock head.
Old Oct 16, 2006 | 09:54 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Jesel has some that look like thay will work just not sure here is the pic from there web sight what do you guys think. Jesel Inc. - Valvetrain Innovation
Old Oct 16, 2006 | 06:00 PM
Guest
Guest
Posts: n/a
You'll have to remove any support/bracing for the center bolts, I havent seen the vette valvecovers inside but that might compromise them just doing that. The adjusters likely wont clear the covers at max lift either, but thats just a guess based on the pic.
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
