Rough Idoling
Old Oct 15, 2006 | 08:43 PM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Rough Idoling
I've noticed that when my car is idoling at a red light or something that the whole car will vibrate like mad...bad enough to make me put it in neutral untill the light is green again...i think its that the idol isnt turned up enough...it idols just above 500 RPM i think when its in drive...in park or neutral it idols at about 750 RPM but its rough...I always thought that it was because it has a carb...but ive heard that a cab should still idol smoothly...it will idol up and down anywhere from about 600 RPM to 800 RPM sometimes...also when i really rev the engine i noticed that the higher the engine revs the brighter my dash lights get lol..then when the engine makes its way back to idol they dim again...same with my headlights and tail lights...what could this be?...thx
Old Oct 15, 2006 | 09:08 PM
[R]ogue's Avatar
Car: 84 bird
it sounds as if the base idle speed is incorrect - i'm gonna assume that your 85 is the same as my 84 and the idle speed on my 84 is 650 RPM in gear which will be approximately 800 in park
the correct idle speed should help with the dimming lights
the rough part of your complaint could be several things - timing, need a tune up etc etc i could make a really really long list of things
Old Oct 15, 2006 | 09:14 PM
Ok...I replaced the spark plugs, adjusted the timing and got my buddy who specializes in engines and transmissions to do a tune up before i began the long trek from Alberta to Newfoundland lol..Also the origional Distributer was shot so I got an Accel dristibuter...altogether ive put 9,000 KM on the car in 3 months lol...could i possibly need another tune up by now?...thx for the reply...also i havent changed my oil in 9,000 KM...im despritly in need of an oil change...im not driving the car now its in my garage but im just wondering what kind of oil i should get...im looking for a performance oil....ive heard Royal Purple a few times...would this be a good oil?..again thx
db057
Jan 10, 2020 08:55 PM
Reid Fleming
Oct 10, 2015 09:56 PM
drumstixer
Sep 29, 2015 03:02 PM
Jlanz55
Sep 29, 2015 08:55 AM
amcnellis
Sep 16, 2015 04:16 PM
