Full or Half Grooved Bearings???
Old Oct 15, 2006 | 05:34 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
After a disaster I'm trying a second rebuild. For my main bearings should I use a full groove or a half groove? Its a mild performance build, 383, Trickflow's, yadda yadda with the standard size journals.
Old Oct 15, 2006 | 05:37 PM
Half
Old Oct 15, 2006 | 06:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I thought you asked this before...?
Well, good luck on your 2nd rebuild, I know i've been there before... It's more fun the second time, just don't get cocky and rush it, you'll screw it up even worse!
Old Oct 15, 2006 | 06:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Yea I've probably been through this but I took some time completly away from the car (school and to clear my head) so now I'm back at square one. Hopefully it will get built properly over winter break since I've picked up my dial indicator, inside and outside micrometers, etc but my front cam bearing seems cocked from the machine shop so I'm already off to a bad start.
Why can't I find any half groove Federal Mogul bearings at Summit???
Old Oct 15, 2006 | 06:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
CLE-MS909P - for main bearings (those are clevite)
SUM-172010 - summit brand (apparently king brand)
Couldn't find FM, you're right, they only do a 3/4 or full groove.
Old Oct 15, 2006 | 06:39 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I guess I don't have a problem with Clevite except for the fact its what was in the motor the first time when it failed but for some reason I wanted to try FM (Clevite quality control I've heard about).
Old Oct 15, 2006 | 06:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, i've heard that about clevite as well - but i'm pretty sure they're still the most popular brand out there, so they can't be that bad.
Remember, if a bearing is failed, and screwed up, that's a good bearing! They're the sacrificial part eh? If your crank is ok, kiss your bearings a "thank you". I went summit for my bearings, and toasted a cam (i'm sure you remember my story), and had to rebuild the motor all over again. I went summit bearings again (nice and cheap), since they did save my crank...
I'm jealous of your tools. Out of curiosity, what did you pay for the outside micrometer set? local purchase?
Old Oct 15, 2006 | 09:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Got a set off Ebay. Not very much but they aren't very good ones either. I take care of my tools and I can't afford an expensive set but these should be fine. I plan to plastigauge and mic them for the heck of it.
Old Oct 15, 2006 | 09:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
ah, apeiron pointed me in the direction of some Ebay micrometers. Couldn't justify the cost at the time. I will after I grad though.
Let me know how well they work compared to the plastigauge, I imagine you can get .0001" accuracy with the mics, but you'll soon find out.
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
