How to change 2 pc. rear main seal with minimal impact?
Old Oct 16, 2006 | 06:15 PM
377Z's Avatar
Car: 2007 Volvo S60R, 2005 Audi A4
Engine: 300HP 2.5L I5, 200HP 2.0L I4
Transmission: TF-80SC, Getrag 6 speed
Axle/Gears: 3.33:1, 3.54:1
1985 LG4. Is there any way to change the rear main without removing the crank? I know the rear main cap needs to come off (duh), can the upper half of the seal be pulled out and the new one "rotated" in? Is there something else that can be done? Am I nuts to even ask? I know it'd probably be best to pull the motor, but I really don't want to tear too far into the bottom end for just a seal, but I'm sick of the dripping and the leaking and the hey hey. Glaven.
Old Oct 16, 2006 | 06:45 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Yes after you pull the main cap you can rotate the old seal out and a new one in. Make sure you offset the seals also when you put them back in. It'll help minimize leaks also.
Old Oct 16, 2006 | 06:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The new rear main seal will include a small plastic guide to prevent you from cutting the new seal on the block when it's installed.
The hardest thing you may have to so is pulling the pan with the engine still in the car. Most of the time, the engine has to be lifted slightly to get the pan out. Still easier than pulling the whole engine.
Old Oct 16, 2006 | 08:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You can drop the pan 1" at least, probably 2", without doing anything but removing the bolts. (no motor raising). If you're slick, you can re&re the seal like that.
oh, drain the oil first too
Old Oct 17, 2006 | 07:58 PM
377Z's Avatar
Thanks for the replies--good to hear it can be done a number of ways. When I get around to it I'll probably just pull the motor, since I'd like to put in a mild cam & maybe refresh the heads.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
