Camshaft question??
Old Oct 18, 2006 | 05:11 AM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Camshaft question??
Just curious...If I were to get a new camshaft would i have to get new valves and valve springs and possibly a higher valve cover to accept the valves opening more?...also how much do you think I would pay for a decent camshaft??...thx
Old Oct 18, 2006 | 10:40 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
You shouldn't need new valves. With the new cam you will need new lifters (unless you have roller lifters). Depending on the cam specs you may need new valve springs to avoid valve float. The cam provider can tell you that. I know Crane & Comp have kits, cam,lifters, springs. Fairly cheap. You shouldn't need new valve covers. Usually only needed when you start changing rocker arms.
Old Oct 18, 2006 | 01:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would replace the springs, retainers, and maybe keepers as well with a new camshaft. Factory crap is heavy (on the valvetrain) and the springs are weak at best.
Cam price depends a lot on what type of cam you're getting.
Old Oct 18, 2006 | 02:17 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll want to replace the valve springs with high perf stock diameter replacement spring when swapping to a aftermarket cam. Keep the valve lift under .510" for near stock motor. a spring like Lunati # 73943 covers most street hyd flat tappet applications. drop on installation
.450" is plenty.
To get an idea of what you should be paying for a new performance cam+ lifters and springs search Summit Racing
Summit Racing - High Performance Car and Truck Parts | 800-230-3030 for the popular hydraulic cams etc.
Allow for shipping To NFLD from OHIO , broker fee and CAN/US $ currency conversion. if you're shopping locally in NFLD or NB/NS allow for some retailer markup. Now your armed with the cam price knowledge to get a competitive price. I've found Canadian performance parts retailers to be generally $way over priced$. Summit, Jegs and others will ship to your door from the US. Specify "US Mail delivery".
Amotion cams in BC is competitive. will ship nation wide (Canada Post) Call or email for pricing. Accelerated Motion Performance Products
A east coast parts source is Flatlander Racing in N.H. Flatlander Racing - High Performance Engine and Racing Parts
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
