motor size
Old Oct 18, 2006 | 08:57 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
motor size
ok, i bought a 92 camaro a few weeks ago, the dealer said it had a 350 but was not original, well i ran the VIN and it said 305, i have an open diff, auto tranny, the valve covers are about 4" wide, and the VIN is 1G1FP23E4NL129768 so if anyone could do a car fax id appretiacte it, sorry about the Noob stuff, im more of a mustang guy, but im not really brand loyal to anyone so im trying to learn and baught a camaro
Old Oct 18, 2006 | 09:27 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
First off,
Welcome to the boards
secondly,
Attempting to decode your VIN 1G1FP23E4NL129768 ...
Warning - VIN longer than expected - ignoring trailing characters but continuing ...
Type Code Contents/Meaning
Country 1 USA
Manufacturer G General Motors
Make 1 Chevrolet
Carline F F-Body
Series P Camaro
Body Type 2 2 door Coupe
Restraint System 3 Manual belts, Driver Airbag
Engine Code E 305 ci/5L V8 L03 (1988-1992)
Check Digit 4 correct
Model Year N 1992
Assembly Plant L Van Nuys
Production Sequence 129768
This car has originally been a 305 .. sounds to me someone lied to you.
It is possible that you had a 350 swap... to know for sure we need the engine casting number.
Which is located behind your distributor, on the bellhousing mating flange. on the driver side it will
state 5.0LG or 5.7LG the numbers will be on the passenger side of the flange
Old Oct 18, 2006 | 09:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Well yea, it was originally a 305, but they said it's now a 350, that right?
Check the casting stamp like nelapse mentioned. Good luck getting to it, it's kinda tricky.
What is this, Z-28, RS, etc? TBI injected, TPI injected, etc?
Old Oct 18, 2006 | 10:21 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Only way to know for sure is to get the casting number off the bolck.
Other than that i would just assume its a stock 305, you wouldnt be the first person that got told its a 350! when its a lousy 305...
Old Oct 19, 2006 | 05:36 AM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
its an RS and an open diff, so i also dont have the g92 rear, so i know it was a 305 i was just trying to figure out ifit was swaped cause the guy said it was, regardless i didnt pay any more for it but i would kinda like the 350, someone told me that the valve covers on the 350 were wider then the 305 is taht true?
Old Oct 19, 2006 | 05:55 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
The valve covers are the same, even if you had a 400.
Old Oct 19, 2006 | 02:23 PM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
where is the VIN on the block located?
Old Oct 19, 2006 | 02:29 PM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
Old Oct 19, 2006 | 02:35 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
It's on the bellhousing, directly behind the drivers side head on a ledge. It is nearly impossible to see on our cars. The casting number will probably be covered in dirt/greese and have a bunch of wires in a wireguard sitting on it.
I ended up having to put a piece of paper on it and rub the numbers onto it with a crayon.
you can check the numbers at MorTec, Inc. Home Page
Old Oct 19, 2006 | 04:16 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Also you should be able to find a partial vin of the origional vech the engine is from located on the front of the block on the ledge in front of the passanger side head, that will be there provided it isnt filled in with paint or if the block had been decked. There will also be a suffix code you can run on mortec if you'd like.
Old Oct 19, 2006 | 06:44 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
funny, I thought I mentioned all of this earlier... I must be going out of my mind
Old Oct 28, 2006 | 02:44 PM
abyliks's Avatar
Car: 02 Mustang
Transmission: 4R70W
thank you, its been in the shop (something with the tranny) i was also wondering what size the stock rear end is and how many spline axles?
also what are the dimentions of the stock muffler cause im planning on replacing it with a force muffler some time this week
and how high is it safe to rev these motors? ive hit 5500 rpms acelerating at WOT but let off when i realized how high it was did i do any damage or is there no problme reving it that high
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
