Why Do I have 4 Oil Rings???
Old Oct 19, 2006 | 01:26 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
On my Weisco pistons I pulled I have four oil control rings but I've never seen four rings before. I have the top and bottom flimsy rings and the oil spacer ring but also on the very bottom another thicker ring that I can't remove.
I've only seen three oil rings before, can someone explain the difference?
Are they specific to the pistons?
Is there any advantage with them?
TIA
Old Oct 19, 2006 | 09:42 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Typically those are needed in 383 engines when people use longer rods. I believe they are called oil support rings or something. Basically when the rods extend into the ring lands they need to add those because the other rings are too filmsy or weak. Make sure ya use em...
Old Oct 19, 2006 | 10:37 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
you are correct sir. i have the very same wiseco pistons and you need those supports for the oil rings when you run a 6.0 rod. the piston you are running is specific and special to this particular combination/application.
Old Oct 19, 2006 | 11:09 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thank you very much! I never knew that, if you try you can learn something new every day.
I'm assuming my new ring set will only come with three oil rings total so I should leave these on the pistons?
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
BOOT77
Sep 16, 2015 08:37 PM
64Chief
Sep 12, 2015 08:05 AM
BOOT77
Sep 5, 2015 03:55 PM
