wats the easy way to get the rear main seal out
Old Oct 19, 2006 | 07:30 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
easiers way to get the rear main seal out? should i use a screw driver and hamer or a pick set. it a 1 peice bye the way.
Old Oct 19, 2006 | 08:03 PM
Vader's Avatar
Since you're going to replace it anyway, it really doesn't matter. A pick/hook is the finesse method, with probably less chance of damage to the crank or seal carrier/bore.
Mind the direction of the dust lip so you can match the orientaiton of the new seal.
Old Oct 19, 2006 | 08:56 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
you say its a one piece rear main, why don't you just unbolt the plate that the seal presses into, then do it. I believe its 4 bolts and 2 oil pan bolts. Makes it much easier.
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
