Not getting any heat
Old Oct 26, 2006 | 06:01 PM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
Im not getting any heat blown into the car. The fan works, but it never blows hot air through my vents. What could be wrong?
Old Oct 26, 2006 | 06:10 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Do some checking first. Engine at normal op temp, feel your heater hoses. Should be hot all the way up to & out of the heater core. If not backtrack feeling hoses. Check the water control valve to make sure you have flow coming out of the valve. Valve is vac operated - so check for vac, or apply external vac source to ensure its working. You could also have a clogged heater core. Any cooling system work done recently?
Good luck
Corky
Old Oct 26, 2006 | 09:25 PM
Car: '88 GTA
Engine: L98 -350TPI
I have had the a/c system evacuated a new pigtail installed behind the a/c controls. But ill check that stuff. thanks.
Old Oct 27, 2006 | 01:53 PM
Corky's Avatar
Engine: 2.8L
May be as simple as the A/C tech knocked off a wire or a vac line.
Corky
Old Oct 27, 2006 | 03:41 PM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
You do have enough coolant correct?
On my old car, the air from my heater would randomly be hot, cold, hot cold, and a couple weeks later, it started overheating
Put some coolant in, cured both problems
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
