305 cam lope
Old Oct 30, 2006 | 01:27 AM
92 Heritage RS's Avatar
Car: 1992 Camaro RS Heritage
Engine: 305 TBI
Axle/Gears: 2.73 open 28 spline
305 cam lope
Hey yall,
I'm wondering if there is a cam with decent lope to it that I can put in my 92 rs 305 that I'm doing a TPI swap on? I understand the vacuum issue involved that's why I'm looking for one that doesn't loose much vacuum. The TPI setup I'm going with is a Mass Air one so it's a little more forgiving. Ultimately, I'm after the lope more than anything, I also only want to change the cam, nothing else. If I'm dreamin' let me know! Thanks!
Old Oct 30, 2006 | 07:51 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
roller right
comp cams has a bunch of cams for your tpi set up
Basic Operating RPM Range: 1,000-5,000 RPM
Intake Duration at 050 inch Lift: 206
Exhaust Duration at 050 inch Lift: 210
Duration at 050 inch Lift: 206 int./210 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 264
Advertised Duration: 262 int./264 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.450 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Valve Lift with Factory Rocker Arm Ratio: 0.450 int./0.480 exh. lift
Lobe Separation (degrees): 112
08-300-8 is the part number
Old Oct 30, 2006 | 10:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you have a lopey cam with a TPI motor, it'll run VERY poorly. TPI is meant to operate well at low RPM, a lopey cam is the opposite. So you end up with the worst of both worlds
The cam jamon mentioned would work great, but won't lope.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
