2 motor ?'s
Old Oct 30, 2006 | 10:19 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
2 motor ?'s
ok to start the motor is in a 77 celica racer.
just the normal stock lower half 4-bolt 72 350. runnin nos, got a noise to it sounded like a lifter. took the covers off and then it sounded like a lower end noise n/p startedd pullin lifters and they were fairly ate up, so we changed the cam out for a better then stock lunati w/458 lift, 240 dur, fired it up for the breakin and it ran like a rape date, noise was still there. pull the pan off and # 1,2 cons were loose, and # 3 piston was about 3/4 of the way busted off at the wrist pin.
any ideas why that would happen?
where the piston cracked on the wall is no groves. I could just run a hone through it right?
and any ideas on what some one would charge for it?
and now would be a good time to go 383 no?
like to get the car into the 10's no nos.
Old Oct 30, 2006 | 03:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I don't think the cam swap and piston problem are related. I'm not totally sure what happened though, your post isn't all that clear.
n/p? it started pulling lifters?
I'd get your machinist to check the bores, it may have ovalized it, and not look bad to the naked eye. Assuming it didn't, and the bores are reasonably in spec, yea, you can just run a hone through it. The machine shop can do it, or you can.
and yea, good time for a 383, since you'll be replacing the bottom end.
Old Oct 30, 2006 | 07:14 PM
Car: 91 RS
Engine: 5.0 tbi
ok I meant that as in I pulled the lifters to see how they were looking. and like 4 were worn crappy so we changed the cam.
figure the car only ran like 10 miles when the noise started.
guy just bought the car for 2500 so go figure.
mint(ish) 77 celica with a chevy motor and trans, supra rear with 4.30 gears and disk break......dude who soldit know it was done for.
Old Oct 30, 2006 | 10:06 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Maybe you were detonating badly and it hammered the rods loose and busted up the piston...
Old Oct 31, 2006 | 05:29 AM
Car: 91 RS
Engine: 5.0 tbi
maybe.......misjudged punch on the nos
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
